crwdns2935069:02crwdne2935069:0
crwdns2933307:0crwdne2933307:0
580.75287
Background
The Craftsman 580.752870 is a pressure washer produced by Sears Brands Management Corporation under the Craftsman brand. The model is gas-powered and is equipped with a Briggs & Stratton 175cc OHV engine. It is designed to deliver a maximum pressure of 2700 PSI and a maximum flow rate of 2.3 GPM. Additional specifications include an engine displacement of 10.69 in3 (175 cc), a bore x stroke of 2.58 in x 2.04 in (65.6 mm x 51.8 mm), and a fuel capacity of 1.6 quarts.
The Craftsman 580.752870 pressure washer comes with several features. It has an overhead valve single-cylinder engine and a ReadyStart system that eliminates the need for priming or choking. The pressure washer also includes a detergent siphon hose which can be utilized for applying detergents. It comes with four quick connect spray tips (0°, 15°, 40°, soap) and an integrated hose wrap and accessory storage. It also has a thermal relief system that cycles water to cool the pump.
Technical Specifications
  • Model Number: 580.752870
  • Product Type: Pressure Washer
  • Maximum Pressure: 2700 PSI
  • Maximum Flow Rate: 2.3 GPM
  • Engine Type: Briggs & Stratton 175cc OHV
  • Engine Displacement: 10.69 in3 (175 cc)
  • Bore x Stroke: 2.58 in x 2.04 in (65.6 mm x 51.8 mm)
  • Spark Plug: Briggs & Stratton 692051, gap 0.020 in (0.50mm)
  • Armature Air Gap: 0.010-0.014 in (0.25-0.36 mm)
  • Valve Clearance (cold engine):
  • Intake: 0.004-0.008 in (0.10-0.20 mm)
  • Exhaust: 0.004-0.008 in (0.10-0.20 mm)
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 20 oz (0.6 L)
Warranty
The Craftsman 580.752870 pressure washer comes with a 2-year limited warranty provided by Sears Brands Management Corporation. This warranty guarantees coverage for any defects in the materials and workmanship of the product. Additionally, the emissions control system of the washer is also warranted for a period of 2 years. However, the warranty does not provide coverage for damages resulting from improper use, lack of maintenance, winter freezing, modifications, or the use of unapproved parts. In the event of defects in the emissions system, Sears commits to repairing or replacing parts at no cost to the owner. To claim the warranty, the owner is responsible for adhering to proper maintenance and use as described in the operator's manual.
Craftsman 580.752870 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 1,567
