crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:05crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
580.7527
Background
The Craftsman Pressure Washer 580.752700 is a gas-operated cleaning device made by Sears, Roebuck and Co. It operates on a 6.75 horsepower Briggs & Stratton engine and is capable of producing water pressure up to 2500 PSI at a rate of 2.2 gallons per minute. The machine is equipped with a 25-foot high-pressure hose and two 32-ounce detergent tanks, allowing for the use of different cleaning solutions. It also comes with four quick-connect spray tips for various cleaning tasks.
In terms of operation, the pressure washer requires fuel and engine oil to run. After connecting a garden hose to the water inlet, the high-pressure hose needs to be attached to the pump outlet and spray gun. The appropriate spray tip should then be attached to the nozzle extension. If a cleaning solution is to be used, the detergent supply valve needs to be turned on. The machine is started by pulling the recoil handle, and the spray gun trigger can be squeezed to operate. Regular maintenance, such as checking the engine oil, pump oil, and spark plug, is essential to keep the pressure washer in good working condition.
Technical Specifications
  • Model Number: 580.752700
  • Product Type: Pressure Washer
  • Engine: 6.75 HP Briggs & Stratton overhead valve engine
  • Displacement: 190cc
  • Pump: Axial cam pump
  • Pressure: Up to 2500 PSI
  • Flow Rate: 2.2 GPM
  • High Pressure Hose Length: 25 ft
  • Detergent Tank Capacity: 2 x 32 oz tanks
  • Fuel Tank Capacity: 1.6 quarts
  • Power Cord: 35 ft GFCI cord
  • Net Weight: 63 lbs
Warranty
The Craftsman Pressure Washer 580.752700 comes with a limited warranty from Sears. Specifically, a 1-year consumer warranty and a 2-year commercial warranty are included with the purchase. This warranty covers defects in materials and workmanship, given that the product is operated and maintained according to the directions in the owner's manual. However, it is important to note that the warranty does not cover normal wear items such as pump oil, spark plugs, and filters. Furthermore, any damage resulting from improper operation, maintenance, winterization, or accessories is not covered by the warranty. To claim the warranty, it is typically required to contact Sears directly, providing them with detailed information about the issue as well as proof of purchase.
Craftsman 580.752700 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 831
