crwdns2935069:04crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
580.75233
Background
The Craftsman Pressure Washer 580.752330, manufactured by Sears, is a gasoline-powered pressure washer equipped with a 6.75 horsepower Briggs & Stratton engine. This device has the capacity to output a maximum pressure of 2550 PSI at a flow rate of 2.0 GPM.
Intended for residential use, this medium-duty pressure washer features a vertical shaft engine coupled with an axial cam pump. It comes with a 25 ft high-pressure hose, insulated spray gun, and four Quick Connect nozzles (0°, 15°, 25°, 40°) for a variety of cleaning applications. The washer also provides a system for applying detergent by connecting the siphon tube to a cleaning solution and using the black soap nozzle. An in-line filter is incorporated to protect the pump from debris.
Technical Specifications
  • Model Number: 580.752330
  • Product Type: Pressure Washer
  • Max Pressure: 2550 PSI
  • Max Flow Rate: 2.3 GPM
  • Detergent Mix: Use as directed
  • Max Water Supply Temp: Not to exceed 100°F
  • Shipping Weight: 63 lbs
  • Engine Manufacturer: Briggs & Stratton
  • Engine Horsepower: 6.75 HP
  • Engine Model: 125K02-0137-E1
  • Engine Bore: 2.69 in (68mm)
  • Engine Stroke: 2.04 in (52mm)
  • Engine Displacement: 190cc
  • Spark Plug Type: Champion RJ19LM or equivalent
  • Spark Plug Gap: 0.030 in (0.76mm)
  • Valve Clearance (cold engine), Intake: 0.005-0.007 in (0.13-0.18 mm)
  • Valve Clearance (cold engine), Exhaust: 0.005-0.007 in (0.13-0.18 mm)
  • Fuel Capacity: 1.6 Quarts
  • Oil Capacity: 20 oz (0.6 L)
  • Oil Type (Above 40°F): SAE 30
  • Oil Type (Below 40°F): SAE 5W-30 or 10W-30
  • Included Accessories: 25 ft high pressure hose, insulated spray gun, four Quick Connect nozzles (0°, 15°, 25°, 40°)
  • Additional Features: Integrated hose reel and nozzle storage, in-line filter
Warranty
The Craftsman Pressure Washer 580.752330 comes with a limited 1 year consumer warranty covering defects in materials and workmanship from the date of purchase. If the product is used for commercial purposes, coverage is provided for 90 days, and for rental use, the coverage period is 30 days. However, the warranty does not extend to consumable parts such as filters, belts, or pump seals that can wear out from normal use. It's also important to note that any damage resulting from improper maintenance or misuse of the product will result in the warranty being voided.
Craftsman 580.752330 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 1,023
