crwdns2935069:05crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
580.7521, 580.752100
Background
The Craftsman 2700 PSi Pressure Washer 580.752100 is a gas-powered pressure washer. It utilizes a 190 cc Briggs & Stratton engine and an axial cam pump, which together are capable of producing up to 2700 PSi of water pressure at a flow rate of 2.5 gallons per minute. This pressure washer is powered by gasoline and has a fuel tank capacity of 1.6 quarts.
The pressure washer comes with a variety of features, including a 25-foot steel-reinforced high-pressure hose and a selection of four nozzles to adjust the spray pattern. It also includes a 1-gallon detergent tank with an injection system and an accessory storage tray. For ease of movement and transport, the pressure washer is equipped with pneumatic tires and a handle. To operate the pressure washer, it requires oil and gasoline to be added to the engine, and a garden hose to be connected to the water inlet. The high-pressure hose is connected to the pump outlet and the spray gun, and the desired nozzle is selected. After setting the fuel valve and choke lever, the engine is started by pulling the recoil starter.
Technical Specifications
  • Model Number: 580.752100
  • Product: Craftsman Pressure Washer 580.752100
  • Engine: Briggs & Stratton 190 cc OHV
  • Pump: Axial cam pump
  • Pressure: Up to 2700 PSi
  • Flow Rate: Up to 2.5 GPM
  • High Pressure Hose Length: 25 ft
  • Cleaning Tank Capacity: 1 gallon
  • Power Source: Gasoline
  • Fuel Tank Capacity: 1.6 quarts
  • Weight: 71 lbs
Warranty
The Craftsman 2700 PSi Pressure Washer 580.752100 comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in both the materials used to make the product and the workmanship. However, it's important to note that any evidence of neglect, misuse, or improper maintenance could potentially void the warranty. To claim the warranty, one would typically need to provide proof of purchase and report the issue to Sears, following their warranty claim procedures.
Craftsman 580.752100 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2942667:0crwdne2942667:0 563
