crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:016crwdne2935069:0
536.88644, 536.886440
Background
The Craftsman Gas Snow Thrower 536.886440 is a snow removal equipment, powered by a 4-cycle engine. It is manufactured by Western Tool & Stamping for Sears under the Craftsman brand. The engine is identified by the model number 143.015005. The operation of the Snow Thrower relies on several components including the engine oil, spark plug, disc drive plate zerk, and fuel. Regular monitoring of engine oil levels and changes, tightening of screws and nuts, checking and replacing the spark plug when necessary, lubricating pivot points and the disc drive plate zerk, and monitoring fuel levels are integral for the proper operation and longevity of the product.
This snow thrower is specifically designed for the removal of snow, a task it achieves by throwing the snow out of its path. It is geared towards ensuring that pathways, driveways, and other areas are clear of snow. Some of its key components include a cylinder, dowel pin, oil drain extension, governor rod, governor lever, throttle spring, oil seal, crankshaft, piston, pin & ring set, and a connecting rod assembly among others. These parts work in unison to deliver the desired snow removal operation.
Technical Specifications
  • Cylinder: 143.015005
  • RPM High: 3550 to 3850
  • RPM Low: 1850 to 2150
  • Crankshaft: 34443B
  • Piston, Pin & Ring Set (Standard): 610118
  • Piston, Pin & Ring Set (0.010" Oversize): 651024
  • Piston, Pin & Ring Set (0.020" Oversize): 651007
  • Ring Set (Standard): 32644A
  • Ring Set (0.010" Oversize): 650691
  • Ring Set (0.020" Oversize): 650691
  • Valve Lifter: 35395
  • Exhaust Valve (Standard): 36441
  • Exhaust Valve (1/32" Oversize): 36443
  • Intake Valve (Standard): 36471
Warranty
The Craftsman Gas Snow Thrower 536.886440 comes with a limited 2-year warranty. This warranty covers any defects in material or workmanship and is valid from the date of purchase. To claim the warranty, it is important to ensure that the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions provided in the owner's manual. If the snow thrower is used for commercial or rental purposes, the warranty applies for only 90 days from the date of purchase. It is important to note that the warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. Additionally, repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual, are not covered by the warranty. Warranty service can be obtained by returning the Craftsman Snow Thrower to the nearest Craftsman Service Center/Department in the United States. Please note that this warranty applies only while the product is in use in the United States.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 699
