crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:03crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
358.79775
Background
The Craftsman Edger 358.797750 is a gardening tool manufactured by POULAN/WEEDEATER for Sears. This product is designed to cut sod with a blade that is regulated by a depth control lever. This lever can be moved forward for full depth edging or rearward for half depth edging. The edger also features a depth adjusting wheel that removes the blade from the cut when the unit is not in use.
The Craftsman Edger 358.797750 operates on a 24cc 2-Cycle gasoline engine. The engine incorporates an on/off switch and a starter rope handle for starting the engine. It also includes a choke for providing additional fuel when starting a cold or refueled engine. The throttle trigger controls the engine speed and is designed to be activated by the right hand. The product also has a primer bulb which circulates fuel to the carburetor. This edger's fueling engine is certified to operate on unleaded gasoline, which must be mixed with a good-quality 2-cycle air-cooled engine oil before operation.
Technical Specifications
  • Engine Type: 24cc 2-cycle gas engine
  • Fuel Type: Unleaded gasoline mixed with 2-cycle air-cooled engine oil at 40:1 ratio
  • Blade Design: Designed to cut sod
  • Depth Adjusting Feature: Wheel to raise/lower blade
  • Depth Control Lever: Adjusts cutting depth - forward for full depth, rearward for half depth
  • Switch: On/off
  • Choke Function: Provides extra fuel when starting cold engine
  • Primer Bulb: Circulates fuel to carburetor
  • Throttle Trigger: Controls engine speed
Warranty
The Craftsman Edger 358.797750 comes with a full one-year warranty from the date of purchase. During this warranty period, Sears will repair any defect in material or workmanship free of charge, provided that the edger is maintained, lubricated, and tuned up according to the instructions in the operator's manual. However, it's important to note that if the edger is used for commercial purposes, the warranty only applies for 90 days from the date of purchase, and if it is used for rental purposes, the warranty only applies for 30 days from the date of purchase. The warranty does not cover expendable items such as rotary and/or edger blades, blade guides, blade adaptors, air cleaners, spark plugs, tire chains, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the operator's manual. To claim the warranty, the Craftsman Edger should be returned to the nearest Sears service center in the United States.
Craftsman 358.797750 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 531
