crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
358.7955
Background
The Craftsman Edger 358.795500 is a gasoline-powered gardening appliance. This 25cc/1.5 cu.in. 2-cycle tool is designed to help with trimming lawns and gardens, featuring a 17-inch cutting path and a 0.080-inch line. It operates on a mixture of unleaded gasoline and synthetic 2-cycle air-cooled engine oil. The edger has various controls and adjustments including an ON/OFF switch, primer bulb, start lever, and coupler. The ON/OFF switch stops the engine, the primer bulb removes air from the carburetor and fuel lines, and the start lever aids in starting the engine. The coupler allows for optional attachments to be installed on the unit.
The Craftsman Edger 358.795500 is also equipped with a trimmer head and a line limiter blade. The trimmer head, coupled with the line limiter blade, makes it possible to precisely control the length of the grass that is being cut. The edger also has a throttle trigger lever, which controls the power output of the engine, and a muffler, which reduces engine noise. For starting convenience, the unit features a starter handle and a primer bulb. The product is intended for occasional use.
Technical Specifications
  • Model Number: 358.795500
  • Product Type: Edger
  • Engine Type: 25cc/1.5 cu.in. 2-cycle engine
  • Fuel: Unleaded gasoline mixed with synthetic 2-cycle air-cooled engine oil at 40:1 ratio
  • Spark Plug Specifications: Replace yearly, gap at 0.025 in
  • Cutting Path: 17 inch
  • Line Thickness: 0.080 inch
  • Emissions Compliance: Certified for moderate use (50 hours)
Warranty
The Craftsman Edger 358.795500 comes with a full one-year warranty on the gasoline-powered Weedwacker Line Trimmer. This warranty covers any defects in materials or workmanship and is valid for one year from the date of purchase. It is important to note that the warranty excludes nylon line, spark plug, and air filter, which are considered expendable parts and may become worn during normal use. If the Weedwacker Line Trimmer is used for commercial purposes, the warranty is applicable for only 90 days from the date of purchase, and for rental purposes, it is applicable for only 30 days from the date of purchase. To claim the warranty, you can bring the Weedwacker Line Trimmer to the nearest Sears store or service center in the United States. It is advised to retain all receipts covering maintenance on the small off-road engine, as Sears recommends, but the lack of receipts or failure to ensure the performance of scheduled maintenance will not deny warranty solely. For any questions regarding warranty rights and responsibilities, you can contact your nearest authorized service center or call Sears at 1-800-469-4663.
Craftsman 358.795500 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 502
