crwdns2935069:02crwdne2935069:0
247.762461
Background
The Craftsman Edger 247.762461 is a lawn maintenance tool designed to create clean, precise lines along the edges of lawns, sidewalks, and gardens. Its functionality is controlled by various components such as a blade control, curb height adjustment lever, blade depth control lever, and a bevel adjustment lever. The blade control, located on the upper handle, is used to operate the edger and its release stops the engine and the edger blade. The curb height adjustment lever, positioned on the rear of the edger, aids in stabilizing the edger while edging grass along a curb. The blade depth control lever, located on the right side of the upper handle, controls the depth of the cut. The bevel adjustment lever, found on the front, left portion of the edger, is used to adjust the angle of the edger blade for different edging or trenching requirements.
The Craftsman Edger 247.762461 uses unleaded gasoline for fuel and engine oil type SAE 30. The engine is provided by Briggs & Stratton. Additional features include a recoil starter which is used to start the engine, and a primer which pumps gas into the carburetor to aid in starting the engine. The edger does not require the primer for restarting a warm engine after a short shutdown. It is designed to meet the safety standards of the American National Standards Institute (ANSI).
Technical Specifications
  • Depth Control Lever: Controls depth of cut
  • Blade Control: Stops engine and blade when released
  • Curb Height Adjustment Lever: Aids in stabilizing edger along a curb
  • Blade Depth Control Lever: Controls depth of cut
  • Bevel Adjustment Lever: Varies angle of edger blade
  • Recoil Starter: Used to start engine
  • Primer: Pumps gas into carburetor to aid starting
Warranty
The Craftsman Edger 247.762461 comes with a Two-Year Full Warranty starting from the date of purchase. This warranty covers any defects in material or workmanship. If the product is found to be defective, it will receive free repair or replacement if repair is unavailable. To claim the warranty, you can visit the website www.craftsman.com for warranty coverage details and to obtain repair or replacement. It is important to note that the warranty does not cover expendable items such as belts, filters, spark plugs, or edging blades that can wear out from normal use within the warranty period. Additionally, product damage resulting from user attempts at product modification or repair, or caused by product accessories, is not covered. The warranty is also void if the product is ever used while providing commercial services or rented to another person. It is advisable to record the model number, serial number, and date of purchase for future reference.
Craftsman 247.762461 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 960
