crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
320.38595
Background
The Craftsman 320.38595, manufactured by Chervon for Sears, is a versatile tool designed for a variety of drilling and driving tasks. The product operates on a 19.2 Volt DC motor and has a 1/2 inch (13mm) chuck. Its no-load speed ranges from 0-470/min at low setting to 0-1800/min at high setting. The drill driver is equipped with a 22-position clutch that includes 1 drill position and 21 torque positions. The product also features a lithium-ion battery and is compatible with a 120-Volt, 60 Hz AC charger.
The Craftsman Drill Driver is designed with a two-speed gearbox, which can be adjusted for low or high speeds depending on the task at hand. The variable-speed trigger switch delivers higher speed with increased trigger pressure and lower speed with decreased trigger pressure. The tool also includes a keyless chuck that allows users to hand-tighten or release the drill bit in the chuck jaws. Other features include a direction-of-rotation selector for changing the direction of bit rotation, an LED worklight for increased visibility, and a fuel gauge for checking battery levels.
Technical Specifications
  • Motor: 19.2 Volt DC
  • Chuck: 1/2 in. (13mm)
  • No-load Speed: LO 0-470/min, HI 0-1800/min
  • Clutch: 22 Position
  • Torque: 600 in.lbs
  • Battery Type: Lithium-Ion
  • Battery Voltage: 19.2 Volt DC
  • Charger Input: 120-Volts, 60 Hz AC only
  • Optimum Charging Temperature: 50°F (10°C) - 104°F (40°C)
Warranty
The Craftsman 320.38595 comes with a one-year limited warranty. This warranty covers any defects in material or workmanship for a period of one year from the date of purchase. If the product is found to be defective and a proof of purchase is provided, the defective product will be replaced free of charge. To claim the warranty and obtain a free replacement, visit the web page www.craftsman.com/warranty. It is important to note that the warranty does not cover the bit, which is considered an expendable part that can wear out within the warranty period due to normal use. Additionally, the warranty is void if the product is used for commercial services or rented to another person. For terms regarding commercial and rental use, refer to the Craftsman warranty web page. It is recommended to save the instructions and read all of them before using the product to ensure safety and proper operation. The warranty is provided by Sears Brands Management Corporation, located in Hoffman Estates, IL 60179.
Craftsman 320.38595 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 351
