crwdns2935069:03crwdne2935069:0
crwdns2933307:0crwdne2933307:0
315.114852
Background
The Craftsman 315.114852 is a portable power tool designed for drilling and driving applications. Manufactured by Diehl Mfg Co for Sears under the Craftsman brand, this drill driver is powered by a 1/2 in., 19.2-volt battery. It features a keyless chuck for hand-tightening or releasing the drill bit in the chuck jaws, and a two-speed gear train for selecting either low or high speeds. The direction of rotation can be altered using a selector located above the switch trigger, and the drill driver incorporates levels located on the top and end of the motor housing to help keep the drill bit level during use.
The drill driver is equipped with a 24-position clutch with a torque adjustment ring for selecting the right amount of torque for different applications. The variable speed switch trigger allows for higher speed with increased trigger pressure and lower speed with decreased trigger pressure. For metal drilling, high-speed steel bits are recommended. In addition, the drill driver comes with a bit storage area located on the base of the drill for storing the bits provided with the drill. The product is compatible with DieHard 19.2 V lithium-ion battery packs and Craftsman 19.2 V nickel-cadmium battery packs.
Technical Specifications
  • Keyless Chuck Size: 1/2 in.
  • Motor: 19.2 Volt DC
  • Switch Type: Variable Speed Reversible (VSR)
  • Gear Train: 2 Speed
  • No Load Speed: 0-400/0-1,400 r/min. (RPM)
  • Clutch: 24 Position
  • Torque: 410 in.lb
  • Charger Input: 120 V, AC only, 60 Hz
  • Charge Rate: 1 hour
Warranty
The warranty for the Craftsman 315.114852 is a one-year full warranty. If the tool fails to provide complete satisfaction within one year from the date of purchase, it can be returned to any Sears store or parts and repair center or other Craftsman outlet in the United States for free repair. If repair proves impossible, a replacement will be provided. However, if the tool is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It is important to note that this warranty gives specific legal rights, and there may be additional rights that vary from state to state.
Craftsman 315.114852 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 770
