crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
358.352161
Background
The Craftsman Chain Saw 358.352161 is a gasoline-powered chainsaw manufactured by Poulan/Weedeater for Sears under the Craftsman brand. It is equipped with various features including a hand guard, throttle lockout, fast idle lock, guide bar, cutters, bar clamp, adjusting screw, and a primer bulb. The chainsaw is designed to facilitate a range of tasks, from cutting wood to performing more complex tasks, such as pruning and tree felling. The product has the capability to maintain a consistent supply of oil to the bar and chain, which is crucial for optimal performance.
The chain saw operates through several mechanisms. The on/stop switch stops the engine, while the throttle trigger controls the engine speed. The starter rope handle is used for starting the engine, and the choke knob provides additional fuel to the engine when starting a cold engine. The throttle lockout is designed to prevent the throttle trigger from being accidentally squeezed. The fast idle lock allows for faster engine speeds during starting, and the guide bar is designed to carry the chain. The cutters are designed to cut wood, while the bar clamp nuts hold the guide bar after adjustments have been completed. The adjusting screw is designed to tension the chain on the guide bar, and the primer bulb circulates fuel to the carburetor. The chain saw also requires regular service and maintenance for optimal performance.
Technical Specifications
  • Model Number: 358.352161
  • Product Type: Chain Saw
  • Engine Type: 2-Cycle
  • Engine Size: 2.2 cu. in./36cc
  • Guide Bar Length: 16 inches
  • Fuel Type: Gasoline
  • Spark Plug Gap: .025 inches
  • Air Filter: Replaceable, cleanable
  • Muffler: With spark arrestor screen
  • Oil Tank: With bar oil fill/cap
  • Guide Bar: With sprocket
  • Chain Tension Adjustment: Manual
  • Chain Catcher: Yes
  • Special Features: On/Stop Switch, Cylinder Shield, Clutch Drum/Sprocket, Handle Screws, Starter Housing, Handguard
  • Maintenance Schedule: Regular cleaning and replacement of spark plug, air filter, fuel filter, and chain. Regular inspection of guide bar and muffler. Lubrication of bar oil fill/cap and sprocket.
Warranty
The warranty for the Craftsman Chain Saw 358.352161 is a full one year warranty. According to the manual, Sears will repair, free of charge, any defect in material or workmanship for one year from the date of purchase, as long as the chainsaw is maintained, lubricated, and tuned-up according to the owner's manual. However, please note that the warranty excludes the bar, chain, spark plug, and air filter, as these are considered expendable parts that may become worn during normal use. To claim the warranty, you can return the chainsaw to the nearest Sears Service Center in the United States. It is important to read and retain the manual for further information and instructions on the warranty.
Craftsman 358.352161 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 819
