crwdns2935069:02crwdne2935069:0
crwdns2933307:0crwdne2933307:0
358.35181
Background
The Craftsman Chain Saw 358.351810 is a gas-powered chainsaw, produced by POULAN/WEEDEATER for Sears, with a 2.4 cubic inch (or 40cc) 2-cycle engine. The chainsaw features an 18-inch guide bar, which is the part that the chain wraps around. This chainsaw is powered by a combination of gasoline and oil, which is mixed and added to the fuel tank. The chainsaw is started by pulling a starter rope, and the engine's speed is controlled by a throttle trigger.
The chainsaw has several features designed for convenience and control. It includes an ON/STOP switch to halt the engine, a chain brake to stop the chain in case of kickback, and a throttle lock-out to prevent accidental triggering of the throttle. It also has a choke/fast idle lever, which provides additional fuel to the engine during cold starts. A primer bulb circulates fuel to the carburetor for quicker starting. The chainsaw also has a chain tension adjustment feature, which compensates for the natural stretch of a new chain during the initial stages of operation.
Technical Specifications
  • Product Type: Chain Saw
  • Model Number: 358.351810
  • Engine Type: 2.4 cu.in./40cc 2-Cycle Gasoline
  • Bar Length: 18 in
  • Features: Chain Brake, Throttle Trigger, Throttle Lock-out, Choke/Fast Idle Lever, Primer Bulb
  • Fuel Type: Gasoline
  • Unit Status: Factory tested and carburetor precisely adjusted
  • Chain Tension: Requires frequent checking due to normal stretching during operation
  • Emission Compliance: Certified to be emissions compliant for various uses (specific standard not mentioned in the context)
  • Safety Measures: Equipped with a chain brake, designed to stop the chain in case of kickback
  • Assembly Status: Fully assembled
  • Spark Arresting Screen: Equipped with a temperature limiting muffler and spark arresting screen
  • Vibration System: Not equipped with an anti-vibration system, intended for occasional use only
  • Certifications: Listed by Underwriters Laboratories, in accordance with American National Standards for Gasoline-Powered Chain Saws Safety Requirements (ANSI B175.1-2000)
Warranty
The warranty for the Craftsman Chain Saw 358.351810 is valid for one year from the date of purchase. This warranty covers any defects in material or workmanship. If the product fails within the warranty period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair is not possible. However, please note that the bar, chain, spark plug, and air filter are considered expendable parts and are not covered by the warranty. If the product is used for commercial or rental purposes, the warranty only applies for 30 days from the purchase date. To file a warranty claim or for any questions regarding warranty rights and responsibilities, customers can contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be obtained at all Sears Service Centers, and Sears-approved replacement parts for emission-related parts will be provided without charge if the part is still under warranty.
Craftsman 358.351810 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 1,352
