crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:03crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
358.35016
Background
The Craftsman Chain Saw 358.350160, manufactured by POULAN/WEEDEATER for Sears, is a gasoline-powered tool used for cutting and trimming trees. The chain saw is powered by a 2.2 cubic inch/36cc 2-cycle engine and features a 16-inch bar for cutting through wood. The saw features various controls and adjustments including an on/stop switch, a throttle trigger, a throttle lockout, a fast idle lock, a choke knob, and a primer bulb. The throttle trigger controls the engine speed, while the throttle lockout and fast idle lock are designed to prevent accidental operation. The choke knob is used to provide additional fuel for cold starts, and the primer bulb circulates fuel to the carburetor for quicker starting. The chain saw is also equipped with a chain tension adjustment feature, which is necessary as it is normal for a new chain to stretch during the first 30 minutes of operation.
The chain saw also comes with additional components for maintenance and repair, including a carburetor assembly kit, a gasket/diaphragm repair kit, a cylinder kit, a piston kit, and a crankshaft assembly. These components allow for the repair and maintenance of the chain saw to ensure its longevity and optimal performance. The carburetor assembly kit includes components such as a high-speed needle, a low-speed needle, needle springs, and limiter caps. The cylinder kit and the piston kit are key parts of the engine that facilitate the combustion process, while the crankshaft assembly is responsible for converting the reciprocating motion into rotational motion to drive the chain. The gasket/diaphragm repair kit is used to replace worn out or damaged gaskets and diaphragms in the carburetor.
Technical Specifications
  • Engine Type: 2.2 cu. in./36cc 2-Cycle gasoline
  • Bar Length: 16 in.
  • Chain Brake: Suitable for commercial logging use
  • Muffler: Temperature limiting with spark arresting screen
  • System: Anti-vibration
  • Safety Standards: Meets ANSI B175.1-1991
  • Certification: Underwriters Laboratories listed
Warranty
The warranty period for the Craftsman Chain Saw 358.350160 is two years from the initial date of purchase. The warranty covers any failures of warranted parts as long as they are not caused by abuse, neglect, improper maintenance, unapproved modifications, or the use of add-on or modified parts. To claim the warranty, the owner should present the lawn and garden equipment engine to an approved SEARS servicing center as soon as a problem exists. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days. Warranty services or repairs can be obtained at any SEARS service center by calling 1-800-473-7247.
Craftsman 358.350160 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 396
