crwdns2935069:03crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
358.79496
Background
The Craftsman Blower 358.794960 is a gasoline-powered blower/vacuum designed and manufactured by Poulan/Weedeater for Sears. It is equipped with a 25cc/1.5 cu.in. 2-cycle engine and can generate wind speeds of up to 205 MPH and an airflow rate of 410 CFM. These features enable the blower to effectively clean debris or grass clippings from driveways, sidewalks, patios, and similar areas.
The Craftsman Blower 358.794960 is also capable of functioning as a vacuum. This dual functionality allows for the collection of dry materials such as leaves, grass, small twigs, and bits of paper. To achieve optimal results when vacuuming, it is recommended to operate the unit at high speed and move slowly back and forth over the material. The design of the blower allows for the vacuum tube to be kept about an inch above the ground for the best results. The engine of the Craftsman Blower 358.794960 is certified to be emissions compliant, making it an environmentally conscious choice for outdoor cleaning tasks.
Technical Specifications
  • Model Number: 358.794960
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Displacement: 25cc/1.5 cu.in.
  • Air Speed: 205 MPH
  • Air Volume: 410 CFM
  • Fuel Type: Gasoline
Warranty
The Craftsman Blower 358.794960 comes with a warranty that lasts for two years from the initial date of purchase. The warranty covers repair or replacement of parts, and any warranted part will be repaired or replaced at no charge to the owner at an approved Sears Service Center. If you have any questions regarding your warranty rights and responsibilities, you can contact your nearest authorized service center or call Sears at 1-800-469-4663. It is important to note that the warranty does not cover failures caused by abuse, neglect, or improper maintenance, and the use of add-on or modified parts can disallow a warranty claim. To file a warranty claim, you should contact your nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs will be provided at all Sears Service Centers.
Craftsman 358.794960 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 438
