crwdns2935069:03crwdne2935069:0
crwdns2933307:0crwdne2933307:0
358.79481
Background
The Craftsman Blower 358.794810 is a versatile tool designed for both residential and commercial use. Manufactured by Poulan/WeedEater for Sears under the Craftsman brand, this blower is known for its reliable performance, durability and repairability. The product features various controls and adjustments, such as a stop switch, throttle trigger, throttle position lever, primer bulb, and a choke lever.
The Craftsman Blower is equipped with mulching blades as a standard feature, which can automatically reduce debris at a ratio of up to 16:1 when using the optional vacuum kit. It also offers a stop switch to halt the engine, a throttle trigger for speed selection, and a throttle position lever for setting engine speed during use. The primer bulb removes air from the carburetor and fuel lines, filling them with fuel for easier start-up. The choke lever assists in cold starting by supplying fuel to the engine. The product operates on unleaded gasoline and synthetic 2-cycle air-cooled engine oil. The blower can be used for sweeping debris or grass clippings and blowing grass clippings, straw, or leaves into piles. It is also useful for cleaning driveways, sidewalks, patios, gutters, screens, grills, porches, and gardens.
Technical Specifications
  • Model Number: 358.794810
  • Product: Craftsman Blower 358.794810
  • Product Type: Blower
  • Power Source: Gasoline
  • Engine Type: 2-Cycle
  • Engine Displacement: 28cc/1.5 cu.in.
  • Maximum Air Velocity: 170 MPH
  • Maximum Air Volume: 470 CFM
  • Mulching Ratio: Up to 16:1
  • Features: Mulching blades, STOP switch, THROTTLE TRIGGER, THROTTLE POSITION LEVER, PRIMER BULB, CHOKE LEVER
  • Emissions Compliance: EPA Phase 1 or Phase 2 and/or CALIFORNIA standards
Warranty
The Craftsman Blower 358.794810 comes with a full warranty that lasts for three (3) years from the date of purchase. If the product fails due to a defect in material or workmanship within this period, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair proves impossible. It is important to note that this warranty applies for only 1 year from the purchase date if the product is used for commercial or rental purposes. The warranty covers only defects in material and workmanship and does not cover expendable items that can wear out from normal use within the warranty period, such as blower tubes, filters, or spark plugs. Additionally, repairs necessary due to accident or failure to operate or maintain the product according to the supplied instructions, as well as preventive maintenance or repairs necessary due to improper fuel mixture, contaminated or stale fuel, are not covered by the warranty. To claim the warranty, customers can contact any Sears Service Center or call 1-800-469-4663.
Craftsman 358.794810 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 533
