crwdns2935069:03crwdne2935069:0
crwdns2933307:0crwdne2933307:0
358.794772
Background
The Craftsman Blower 358.794772 is a gasoline-powered blower/vacuum manufactured by Poulan/Weedeater for Sears under the Craftsman brand. It features a 25cc, 1.5 cubic inch 2-cycle engine that provides 215 mph of air speed and an air volume of 470 cubic feet per minute. The blower is equipped with a throttle position lever that allows the setting of engine speed during use, a primer bulb for removing air from the carburetor and fuel lines, and a start lever for supplying fuel to the engine.
The Craftsman Blower 358.794772 is designed to vacuum dry materials such as leaves, grass, small twigs, and bits of paper, and it can also blow debris. The vacuum and blower functions can be switched according to the user's needs. It has been certified to be emissions compliant for different uses including moderate (50 hours), intermediate (125 hours), and extended (300 hours). It is a reliable and durable tool suitable for both residential and commercial use.
Technical Specifications
  • Model Number: 358.794772
  • Product: Craftsman Blower 358.794772
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Displacement: 25cc/1.5 cu.in.
  • Max Air Speed: 215 MPH
  • Max Air Volume: 470 CFM
  • Fuel Type: Gasoline
  • Starting System: Manual pull start
  • Throttle Position Lever: Designed for setting engine speed during blower use only
  • Primer Bulb: Removes air from carburetor and fuel lines to aid in starting
  • Start Lever: Helps supply fuel to the engine for starting
  • Safety Features: Safety glasses and hearing protection required; heavy, long pants, long sleeves, boots, and gloves recommended
  • Operating Tips: Hold blower with muffler side facing away from body; limit throttle speed to reduce noise levels; use rakes and brooms to loosen debris before blowing; be cautious of children, pets, open windows, or freshly washed cars; use full blower nozzle extension for ground work
  • Fueling: Requires a mixture of gasoline and synthetic 2-cycle air-cooled engine oil at a ratio of 40:1
Warranty
The Craftsman Blower 358.794772 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may arise within two years from the date of purchase. If the product fails due to such a defect, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement, if repair is not possible. However, please note that the warranty does not cover the spark plug and air cleaner, as they are considered expendable parts that can wear out within two years of normal use. It is important to follow the operator's manual for proper usage and maintenance in order to avail of this warranty. If the product is used for commercial or rental purposes, the warranty is applicable for only 30 days from the date of purchase. To claim the warranty, contact Sears Service Centers at 1-800-469-4663.
Craftsman 358.794772 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 76
crwdns2959996:0crwdne2959996:0 923
