crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
358.79412, 358.794120
Background
The Craftsman Blower 358.794120 is a gasoline-powered tool manufactured by Poulan/Weedeater for Sears under the Craftsman brand. The blower serves to clear debris or grass clippings from driveways, sidewalks, patios, and similar areas. It can also be used to blow grass clippings, straw, or leaves into piles, around joints, or between bricks. The blower operates on a 25cc/1.5 cu.in. 2-Cycle engine, delivering an air speed of up to 185 MPH and an air volume of 385 CFM.
The blower is equipped with several features designed to improve its performance and ease of use. The throttle lever is used to select the desired engine speed and to stop the engine. The primer button aids in starting the engine by removing air from the carburetor and fuel lines and filling them with fuel. The choke lever supplies fuel to the engine to aid in cold starting. The blower can be operated at the lowest possible throttle speed to reduce noise levels. It also has a rear handle, allowing the user to have a firm grip while operating the blower.
Technical Specifications
  • Model Number: 358.794120
  • Product: Craftsman Blower 358.794120
  • Product Type: Blower
  • Engine Type: 2-Cycle
  • Engine Displacement: 25cc/1.5 cu.in.
  • Air Speed: 185 MPH
  • Air Volume: 385 CFM
  • Fuel Type: Gasoline
  • Throttle Lever: Used to select desired engine speed and stop the engine
  • Primer Button: Removes air from the carburetor and fuel lines and fills them with fuel for easier starting
  • Choke Lever: Supplies fuel to the engine for cold starting
  • Blower Tube: Directs the airflow from the blower
  • Rope: Used to start the engine
  • Rear Handle: Provides a grip for holding and maneuvering the blower
Warranty
The Craftsman Blower 358.794120 comes with a full one-year warranty from the date of purchase. During this warranty period, Sears will repair any defects in material or workmanship free of charge, as long as the blower is maintained, lubricated, and tuned up according to the instructions in the manual. However, please note that the warranty excludes certain parts such as blower tubes, spark plug, and air cleaner, which are considered expendable and may become worn during normal use. If the blower is used for commercial purposes, the warranty applies for 90 days, and if it is used for rental purposes, the warranty applies for 30 days from the date of purchase. To claim the warranty, you can return the blower to the nearest Sears store or service center in the United States. It is important to know that this warranty applies only while the product is in use in the United States.
Craftsman 358.794120 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 347
