crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
921.15312
Background
The Craftsman Air Compressor 921.153120 is a 2-gallon, 1HP oil-lubricated, direct drive air compressor. It is manufactured by Midwest Air Technologies Inc. for Sears under the Craftsman brand. The product is designed to provide a source of compressed air for various applications. The air compressor is equipped with a number of features including a check valve, quick connect, tank pressure gauge, regulator gauge, regulator, pressure relief valve, pressure switch, air intake filter, and tank drain valve.
The check valve retains air pressure inside the tank when the pump is not in operation. The quick connect feature allows for easy attaching and removing of the air hose. The tank pressure gauge indicates the reserve air pressure in the tank, while the regulator gauge indicates the outgoing air pressure to the tool. The regulator controls the air pressure coming from the air tank. The pressure switch automatically starts the motor when the air tank pressure drops below the factory set cut-in pressure and stops the motor when the air tank pressure reaches the factory set cut-out pressure. The air intake filter provides clean air to the pump and the tank drain valve is used to drain condensation from the air tank.
Technical Specifications
  • Model Number: 921.153120
  • Product: Craftsman Air Compressor 921.153120
  • Product Type: Air Compressor
  • Pump: Oil-lube direct drive
  • Air Tank Capacity: 2 Gallons
  • Motor: 1.0 HP (Induction)
  • Cut-in Pressure: 95 PSI
  • Bore: 1.65"
  • Cut-out Pressure: 125 PSI
  • Stroke: 1.26"
  • SCFM @ 90 PSI: 2.4
  • Voltage Single Phase: 120 VAC
  • Oil Capacity: 90 mL or 3 oz.
  • Minimum Circuit Requirement: 15 Amps
  • Oil Type: SAE 30 Non-detergent
Warranty
The Craftsman Air Compressor 921.153120 comes with a one-year full warranty. This warranty covers any defects in material or workmanship that may occur within one year from the date of purchase. If the product fails due to such defects, customers can return it to any Sears store, Sears Service Center, or other Craftsman outlet for free repair or replacement if repair is not possible. It is important to note that the warranty only applies for 90 days if the product is used for commercial or rental purposes. To claim the warranty, customers can simply bring the product to the aforementioned locations for repair or replacement. This warranty provides specific legal rights to customers, and they may also have additional rights that vary from state to state.
Craftsman 921.153120 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 491
