crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
919.19541
Background
The Craftsman Air Compressor 919.195410 is a portable, oil-lubricated, single-stage air compressor. It is designed for a variety of applications, including powering air tools and inflating tires. The compressor is equipped with a 6.0 horsepower motor and a 25-gallon air tank, providing a reliable source of compressed air. It operates at a voltage of 120/240 and requires a minimum branch circuit of 15 amps. The compressor has a maximum developed horsepower of 6.0 with a bore of 2.875" and a stroke of 2.0".
The compressor features an approximate cut-in pressure of 120 and a cut-out pressure of 150. It delivers a standard cubic feet per minute (SCFM) of 8.6 at 40 pounds per square inch gauge (PSIG) and 6.8 SCFM at 90 PSIG. The product also includes a built-in cooling system, a check valve, a pressure release valve, and an air intake filter. The cooling system is designed to expel large amounts of air through the vent holes, indicating its proper functioning. The check valve allows compressed air to enter the tank when the compressor is operating and retains the air pressure when the compressor reaches cut-out pressure. The pressure release valve automatically releases compressed air from the compressor head and the outlet tube when the compressor reaches cut-out pressure or is shut off. The air intake filter cleans the incoming air to the pump.
Technical Specifications
  • Model Number: 919.195410
  • Product Type: Air Compressor
  • Max. Developed HP: 6.0
  • Bore: 2.875"
  • Stroke: 2.0"
  • Voltage-Single Phase: 120/240
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity: 25 gallons
  • Approximate Cut-in Pressure: 120
  • Approximate Cut-out Pressure: 150
  • SCFM @ 40 psig: 8.6
  • SCFM @ 90 psig: 6.8
Warranty
The Craftsman Air Compressor model number 919.195410 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the product fails due to such defects within one year from the date of purchase, you can return it to the nearest Sears Service Center in the United States, and it will be repaired free of charge.
However, if the air compressor is used for commercial or rental purposes, the warranty will apply for only ninety days from the date of purchase.
To claim the warranty, you need to return the product to your nearest Sears Service Center.
Please note that this warranty gives you specific legal rights, and you may have other rights which vary from state to state.
Craftsman 919.195410 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 572
