crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
919.1676
Background
The Craftsman Air Compressor 919.167600 is a portable air compressor manufactured by Ingersoll Rand for Sears under the Craftsman brand. It operates with a running horsepower of 1.6, and is powered by a single phase voltage of 120V/60HZ. The air compressor has an air tank capacity of 26 gallons and operates within a pressure range of approximately 130 PSI (cut-in) to 160 PSI (cut-out). It offers a SCFM of 6.3 at 40 psig and 4.9 at 90 psig, tested per ISO 1217 standards.
The air compressor is equipped with a universal quick-connect body that accepts the three most popular styles of quick-connect plugs: Industrial, automotive (Tru-flate), and ARC. It also features a drain valve at the base of the air tank for draining condensation, an advanced design cooling system with an engineered fan, an air compressor pump for compressing air into the air tank, and a check valve that allows compressed air to enter the air tank. The air compressor also includes a pressure release valve and an air intake filter for cleaning incoming air. The motor is protected by a thermal overload protector that shuts off the motor if it overheats.
Technical Specifications
  • Model Number: 919.167600
  • Running Horsepower: 1.6
  • Bore: 2.875"
  • Stroke: 1.45"
  • Voltage-Single Phase: 120V/60HZ
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity (gallons): 26
  • Approx. Cut-In Pressure: 130 PSI
  • Approx. Cut-out Pressure: 160 PSI
  • SCFM @ 40 psig: 6.3
  • SCFM @ 90 psig: 4.9
Warranty
The Craftsman Air Compressor 919.167600 comes with a full warranty that lasts for one year from the date of purchase. This warranty covers any failures of the product due to defects in material or workmanship. If such a failure occurs, Sears, the manufacturer, offers to either repair or replace the product free of charge. To claim the warranty, you can contact Sears at 1-800-4-MY-HOME to arrange for repair, or return the product to the place of purchase for replacement.
However, if the product is used for commercial or rental purposes, the warranty period is shorter, lasting only ninety days from the date of purchase.
This warranty provides you with specific legal rights, but you may also have other rights which vary from state to state.
Craftsman 919.167600 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 1,093
