crwdns2935069:02crwdne2935069:0
919.16644
Background
The Craftsman Air Compressor 919.166440, manufactured by Ingersoll Rand for Sears, is a tank-mounted model designed to provide a reliable source of compressed air for various applications. The unit operates on a single phase 120V/60HZ/1 PH power supply, making it suitable for standard household use. It has a 1.5 horsepower motor and an air tank capacity of 15 gallons. The compressor has a stroke of 1.25 inches and a bore of 1.875 inches.
The compressor is designed to automatically start when the air tank pressure drops below the factory set "cut-in" pressure and stop when the air tank pressure reaches the "cut-out" pressure. It delivers 4.9 SCFM (Standard Cubic Feet per Minute) at 40 psig and 3.5 SCFM at 90 psig, providing ample power for various air tools. The unit is equipped with a regulator to control the air pressure, a drain valve for condensation removal, and an advanced cooling system to maintain optimal operating temperatures. With these features, the Craftsman Air Compressor 919.166440 is a durable and reliable tool for both professional and home use.
Technical Specifications
  • Model Number: 919.166440
  • Product Type: Air Compressor
  • Running Horsepower (HP): 1.5
  • Bore and Stroke: 1.875" (Bore), 1.25" (Stroke)
  • Voltage: Single Phase 120V/60HZ/1 PH
  • Minimum Branch Circuit Requirement: 15 amps
  • Fuse Type: Time Delay
  • Air Tank Capacity: 15
  • Approximate Cut-In Pressure: 120
  • Approximate Cut-Out Pressure: 150
  • SCFM @ 40 psig: 4.9
  • SCFM @ 90 psig: 3.5
  • Continuous Running Capability: Yes, but recommended duty cycle is 50%-75% (should not run more than 30-45 minutes in any given hour for longevity)
Warranty
The Craftsman Air Compressor model 919.166440 comes with a full one year warranty from the date of purchase. This warranty covers any defects in material or workmanship. If the product fails within this period, Sears will either repair or replace the air compressor free of charge.
To claim the warranty, contact the nearest Sears Service Center at 1-800-4-MY-HOME to arrange for repair. Alternatively, you can return the air compressor to the place of purchase for replacement.
Please note that if the air compressor is used for commercial or rental purposes, the warranty only applies for ninety days from the date of purchase.
This warranty provides you with specific legal rights, and you may also have other rights which vary from state to state.
Craftsman 919.166440 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 821
