crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
919.152812
Background
The Craftsman Air Compressor 919.152812 is a product developed by Ingersoll Rand for Sears. This air compressor is equipped with a 60-gallon vertical receiver tank and operates on a 240V single phase. It delivers an air pressure of up to 125psi, with an air delivery capacity of 15.0 scfm at 40psi and 11.5 scfm at 90psi. The motor of this compressor is an AOSmith AC Motor, which can reach a maximum of 3450 RPM. The motor operates on 230v, 14 amp, 60 hz, and 56Z frequency. The pump, designated as AC-0102, is permanently lubricated, indicating its durability and longevity.
This air compressor is primarily used for tasks where high pressure air is required. It is suitable for a variety of applications, from inflating tires to powering air tools. The large tank capacity allows for extended use, while the high maximum pressure ensures efficient operation. The permanently lubricated pump contributes to the compressor's reliability and reduces the need for regular maintenance.
Technical Specifications
  • Model Number: 919.152812
  • Product Type: Air Compressor
  • Max Pressure: 125psi
  • Receiver Tank: 60-Gallon Vertical
  • Voltage: 240V Single Phase
  • Air Delivery: 15.0 scfm at 40psi, 11.5 scfm at 90psi
  • Motor: AOSmith AC Motor
  • Motor Speed: Max 3450 RPM
  • Motor Voltage: 230v
  • Motor Amps: 14 amp
  • Frequency: 60 hz, 56Z Frequency
  • Lubrication: Permanently Lubricated
  • Pump Number: AC-0102
  • Electrical Circuit: Requires time delay fuses
  • Extension Cords: Recommended cord: 3 wire - 12 ga., maximum 50 ft. long
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,241
