crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Why is it not spinning anymore only used once |
It won't heat up where. is the internal fuse if there is onr |
It will just keep rotating and beeping |
Won’t get hot |
Background and Identification
The Conair InfinitPRO Curl Secret was released on June 18, 2013. Identified by model number CD203R. The device holds the following United States Pantents: D717,000; 8,607,804; 8,869,808; 8651,118; 8,733374.
Conair InfinitPRO Curl Secret is a hair curling device. The device provides a nontraditional way to curl hair. The hair is gently wound around the cylinder as it revolves. The hair is warmed as it is revolving so that the curls stay once the device is removed. The Conair InfinitPRO Curl Secret has 2 heat levels, the highest temperature being 400 ⁰F, and 3 timer settings.
There are some problems that have been found online about this device. There have been issues with hair being burnt after prolonged exposure in the device. Mechanical issues that have been found, include the curling motor failing and overheating.
