crwdns2943011:0crwdne2943011:0
crwdns2943013:0crwdne2943013:0
crwdns2862637:0crwdne2862637:0
crwdns2869081:0crwdne2869081:0
crwdns2933307:0crwdne2933307:0
crwdns2934263:01crwdne2934263:0
crwdns2961394:0crwdne2961394:0
Troubleshooting
If you are having troubles with the Beko DHR73431 and need additional help, here is the troubleshooting page.
Background
The Beko DHR73431 is a front-loaded, slim household tumble dryer. It uses heat sensing technology to measure dryness in conjunction with its heat-pump features to save on energy-usage. Its max listed capacity is 7kg and it comes with 16 programmes that include cotton, synthetic, delicates, refresh, timed dry, sportswear and jeans.
Heat-pump dryers operate by circulating air through the drum and removing the moisture from the clothes, turning it into water that can be captured and removed through the drain hose. These types of dryers circulate the air instead of exhausting it, which is what allows the dryer to use less energy. The parts of the DHR73431 that require regular maintenance are specified in the manual Beko provides as the lint filter and inner door surface, the sensor, water tank, filter drawer, and evaporator.
The DHR73431 is a part of a series of dryers that include two variants, the white DHR73431W and the black DHR73431B. They both come with other safety and convenience features like a remaining-time display, a child lock, drum light, and fullness indicator for the water-tank which has to be regularly drained. Before ordering any parts for the Beko dryer, it necessary to check the full model number on the appliance label and to ensure that any repair guides correspond to the model that you have.
For this dryer, Beko was able to achieve an A++ energy-efficiency class rating with an annual energy consumption of 209kWh which is about one third of the annual energy usage of average electric dryers. These are averages which will vary based of number of uses, size of the loads, and selected programmes.
Identification
The Beko DHR73431W is the white model of the Beko DHR73431. It is a front-loaded dryer with a round door, a control panel above the door, and vents at the bottom of the front face. The type label is printed right below the drum opening. Before making any repairs or replacements, the label should be read and confirmed that DHR73431W or DHR73431B is listed.
Technical Specifications
Main Features
  • Model Codes: DHR73431W / DHR73431B
  • Drying Technology: Heat Pump
  • Dryness Control Method: Sensor
  • Drying Capacity: 7kg
  • Energy Efficiency Class: A++
  • Time Remaining Display
  • Number of Programmes: 16
  • Position of Water Tank: Up
  • Drum Light
  • Electrically-Operated Child Lock
  • Water Tank Full Indicator
  • Clean Filter Indicator Light
  • Auto-Cooldown Phase
  • Cool Tumble
  • Bi-Directional Drum Action
Dimensions & Weights
  • Product Dimensions (mm): 589 x 597 x 846
  • Net Weight: 44kg
Connection & Installation
  • Amperage: 4 A
  • Total Power: 900 W
  • Heater Wattage Max: 0 W
  • Voltage/Frequency: 230-240 V / 50 Hz
  • Direct Drain Hose Supplied With The Product
  • Minimum Ambient Temperature: 5 °C
Functions
  • End of Cycle Buzzer
  • Cancel End of Cycle Buzzer
  • Time Delay
  • Auto Anti-Creasing
Additional Information
Beko DHR73431 Product Page
Beko DHR73431W Product Fiche
Beko DHR73431 User Manual
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
43,984 crwdns2915208:0crwdne2915208:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,966crwdne2935297:0
crwdns2936753:030crwdne2936753:0 116
crwdns2959996:0crwdne2959996:0 3,307
