crwdns2935069:013crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The Barreto Log Splitter model E920LSHX is a log splitter with 20 tons of splitting force and a 790-pound frame. The splitter’s knife plate features high-wear nylon pads, and the machine includes torsion axle suspension that is designed to reduce bounce and improve tow-ability. The torsion axle suspension can be moved to three different positions to increase or reduce tongue weight. When using the splitter in the vertical position, the cushion-mounted log cradle is designed to move out of the way. Spring-loaded lock bars keep the splitter in place during use and a rubber bump stop protects the machine when transitioning from the vertical to the horizontal position. The splitter’s engine is mounted on rubber insulators to protect it from excessive vibrations when operating or towing.
The E920LSHX model log splitter includes a Honda GX270 engine that produces 8.5 horsepower at 3,600 revolutions per minute. The engine produces a net torque of 14.1 foot-pounds at 2,500 revolutions per minute. It can hold up to 5.6 quarts of gasoline and 1.16 quarts of engine oil. Honda recommends using unleaded 86 octane or higher fuel for this engine.
The E920LSHX model log splitter can be identified by its red body and the name “Barreto” printed in black capital letters with a white background in several locations on the machine, including on the side of the vertical portion of the splitter.
Technical Specifications
  • Acme Tools Brand Name: BARRETO MFG
  • Acme Tools Part Number: E920LSH
  • Assembled Weight (lbs): 790
  • Blade Material: High Carbon Wear-Alloy
  • CSA Certified: No
  • Color / Finish: Red with Black
  • Country of Origin (numeric): USA
  • Cutting Wedge (in): 8
  • Cycle Time (sec): 20
  • Cylinder Diameter (in): 4
  • ETL Listed: No
  • Engine: Honda GX270
  • Engine Displacement (cc): 265
  • Fenders: No
  • Fuel Tank Capacity (gal): 1.6
  • Fuel Type: Gasoline
  • Hydraulic Fluid Capacity (gal): 7
  • Hydraulic Fluid Included: No
  • Internal Supplier Part #: E920LSH
  • Internet Product Code (IPC): E915E52D8F6
  • Log Cradle Included: Yes
  • Log Splitter Capacity: 25 in.
  • MFG Model # (Series): 920LSH
  • MFG Part # (OEM): 920LSH
  • Manufacturer Warranty: Limited Lifetime
  • Maximum PSI: 2750
  • Operating Position: Horizontal or Vertical
  • Product Name: 20 Ton Log Splitter, Honda Engine
  • Recommended Oil and Capacity: 34 oz
  • Small Engine Maximum Horsepower (hp): 9
  • Small Engine Maximum Torque (ft-lbs): 14
  • Splitting Force (tons): 20
  • Start Type: Pull
  • Towable: Yes
  • UPC: 405920000022
  • Wheel Diameter (in): 18
Additional Information
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 60
crwdns2959996:0crwdne2959996:0 8,872
