crwdns2933307:0crwdne2933307:0
Features
  • 3.5' Touch IPS display with resolution of 320x240
  • Integration with the Bambu Ecosystem
  • Magnetic build plate
  • Native support for AMS Lite
  • Support with an adapter for other AMS
  • As low as 48 dB with noise cancellation
  • 1080p low frame-rate camera
  • Active flow rate compensation for smoother corners
Body Specifications
  • Build Volume: 256x256x256
  • Build Materials: Steel and aluminum frame with plastic snap-on covers
  • Inactive Footprint: 385 x 410 x 430 mm (15 x 16 x 17 in)
  • Active Footprint: 385 x 525 x 430 mm (15 x 21.5 x 17 in)
  • Weight: 8.4 kg (18.3 lbs)
Filaments
Supported
  • PLA
  • PETG
  • TPU
  • PVA
Supported with modifications
  • Abrasive filaments like wood infused filaments with hardened toolhead
  • ABS, ASA, PC, PA with an enclosure (Not recommended)
Not Supported
  • PEEK
  • PET
  • PP
  • Metal Filaments
Print Speed
  • Four Speeds: Silent, Standard, Sport, Ludicrous
  • Max Toolhead Speed: 500 mm/s
  • Max Toolhead Acceleration: 10,000 mm2/s
  • Max Flow Rate: 28 mm3/s at ABS (Model: 150 * 150 mm single wall w/ Bambu ABS @ 280°C)
Heatbed
  • Build Plate: Removable, Magnetic
  • Supported Plates: All of the Core-XY beds
  • Temps: up to 100°C (212°F)
Toolhead
  • Hot End: All-Metal
  • Extruder Gear Material: Hardend Steel
  • Nozzle Material: Stainless Steel
  • Max Hot End Temprature: 300 °C (572 °F)
  • Included Nozzle Diameter: 0.4 mm
  • Supported Nozzle Diameters:
    • 0.2 mm
    • 0.6 mm
    • 0.8 mm
  • Filament Cutter: Yes
  • Supported Filament Diameter: 1.75 mm
  • Easy Replace Nozzle: Yes
Sensors
  • Monitoring Camera: 1080p Low Rate Camera (Timelapse Supported)
  • Filament Run Out Sensor: Yes
  • Filament Odometry: Yes
  • Power Loss Recover: Yes
  • Filament Tangle Sensor: Yes
Electrical Specifications
  • Input Voltage: 100-240 VAC, 50/60 Hz
  • Max Power: 150 W
Software
  • All Bambu Software: Compatible
  • Third Party Slicer Support: Yes provided the software exports export standard Gcode such as SuperSlicer, PrusaSlicer and Cura. Certain advanced features may not be supported.
  • Operating System: MacOS, WindowsOS, AndroidOS
Connectivity
Wifi
  • Frequency Range:
    • 2412 MHz - 2472 MHz (CE)
    • 2412 MHz - 2462 MHz (FCC)
    • 2400 MHz - 2483.5 MHz (SRRC)
  • Transmitter Power (EIRP):
    • ≤ 21.5 dBm (FCC)
    • ≤ 20 dBm (CE/SRRC)
  • Protocol: IEEE 802.11 b/g/n
  • LAN-Only Mode: Supported
Other
  • USB
  • Bambu-Bus for AMS
  • Micro SD Card
Credit
  • Thank you to not-ethan for writing the A1 Mini Page in which this is based off of!
Documents
Lucas
crwdns2935283:009/25/25crwdne2935283:0
176 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 99
crwdns2936753:030crwdne2936753:0 372
crwdns2959996:0crwdne2959996:0 2,616
