crwdns2911028:0crwdne2911028:0
crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The Aeroneb Pro is a multi-patient use, mesh vibrating nebulizer. This product is manufactured by Aerogen. The Aeroneb Pro nebulizer is used for aerosol therapy. With the appropriate sanitization, the Aeroneb Pro can be reused among the patients which makes it suitable for hospital environments. It is also suitable for portable operations because it operates without compressed gas.
 The Aerogen Pro is a nebulizer along with T-piece (T-shaped tube), which comes with an attached control module. This nebulizer facilitates the delivery of physician prescribed inhalation medication for all age groups of people. With the on and off vibrating force on the other side of the mesh, it generates fine & uniform sized particles. The mesh are 5mm in diameter, with 1000 precision of holes and 128 vibrations/second. This allows the deep lung penetrations which makes the medicines more efficient and provides patients with positive pressure breathing assistance.
 This product was launched in 2007 and is now globally available. There are 3 ways to use this nebulizer: through a ventilator circuit, with adult or pediatric face masks, or with a mouthpiece for greater flexibility in use.
Technical Specifications
Included:
·      Control module
·      Nebulizer unit with filler cap
·      Adult tee with silicone plug
·      AC/DC adapter
·      Equipment adapter
·      Instruction manual
 Power Supply:
·      Can operate from AC/DC adapter (input 100 to 240 VAC 50/60Hz, output 9 V)
 ·      Consumption: <6.5 watts (charging), <2.0 watts (nebulizing)
·      Power requirement ∼1.5 W
·      Atmospheric Pressure: 450 to 1100 hPa
·      Humidity 15 to 95% relative humidity
Physical Components:
 ·      Medication cup capacity: 10 mL
·      Control Module weight: 230 grams (8.1 oz.)
·      Aerogen Pro Controller Dimensions 33mm H x 75mm W x 131mm D
·      Controller Cable Length 1.8 m (5.9 ft.)
 ·     AC/DC Adapter Cable Length 2.1 m (6.7 ft.)
·      Nebulizer Unit weight: 25 grams (0.9 oz.)
·      (Mesh replacement typically required after 6 to 12 months)
·      Nebulizer ''Dimensions (inch) L x W x H 45 mm H x 50 mm W x 50
Noise Level:
 ·      Silent operation: < 35 dB measured at 0.3 m distance
 ·      Frequency: Nebulizer Unit: 128 kilohertz (kHz).
 ·      Multiple patient use: Autoclavable at 132ºC -135ºC(270ºF - 275ºF)
Additional Information
Aerogen Pro instructions manual and FAQ
System instruction and troubleshooting
Cleaning and disinfection of Aeroneb Pro
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2959996:0crwdne2959996:0 1,820
