crwdns2934263:02crwdne2934263:0
crwdns2933315:07crwdne2933315:0
crwdns2934263:09crwdne2934263:0
crwdns2934263:05crwdne2934263:0
Troubleshooting
Track down a number of hardware problems using the Acer Chromebook C720 Troubleshooting Page
Upgrades
  • Solid State Drive (SSD): 16 or 32 GB mSATA come standard with the Acer C720. You can upgrade this drive with relative ease with a replacement of your choice.
  • Other: Any other upgrades to be desired such as memory (RAM), or CPU can only be upgraded by replacing the motherboard with the version in line with the upgrade you are looking for. Memory can be upgraded to 4 GB and the CPU can be upgraded to an Intel Core i3-4005U.
Identification and Background
The Acer C720 is the second generation of Acer Intel based Chromebooks. There are many submodels that vary from any combination of color, memory size (2 GB, and 4 GB), CPU (Intel Core i3-4005U 1.7 GHz and Intel Celeron 2955U 1.4 GHz), and a model with touchscreen.
You can quickly identify your Acer C720 submodel with the Chromebook working or not as this method does not require you to have it turned on. Which could be important seeing as you most likely need a repair. With your Chromebook in hand close the lid lightly with one hand on each corner of the screen to prevent damage to the display when closing due to torsion. With the top side of the closed Chromebook facing upwards gently flip the C720 over and place it on a flat and well lit surface. On the underside of the C720 there will be four stickers that contain various pieces of information about your C720. The sticker that we are looking for is the white sticker. It contains a few lines of text. Look for the SNID. It should be 11 numbers long. Take this number and use it on the following website to check your model. Acer System Information
Additional Information
Kelsea Weber
crwdns2935283:011/12/15crwdne2935283:0
21.631 crwdns2915208:0crwdne2915208:0
crwdns2935297:032crwdne2935297:0
iFixit, Team S1-G1, Weber Summer 2018 crwdns2935289:0iFixit, Team S1-G1, Weber Summer 2018crwdne2935289:0
FIX-WEBER-SU18S1G1
crwdns2935297:0396crwdne2935297:0
crwdns2936753:030crwdne2936753:0 73
crwdns2959996:0crwdne2959996:0 13,004
