Carburetor
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
I need a complete wiring harness for a 2006 |
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
The drain will not stop leaking |
The foot shifter is not going into neutral shifter is still springing |
How is vacuum lines routed on the 350 Honda rancher |
crwdns2935065:0crwdne2935065:0
crwdns2935077:02004, 2005, 2006 Honda Rancher 350 Four Wheelercrwdne2935077:0
Background and Identification
The Honda Rancher line started in 2000 with the first Rancher 350 model. The Honda Rancher was one of the first all-terrain-vehicles (ATV) to include a longitudinally mounted motor. In 2006, the production of the 350cc version ceased. The Rancher 350 was available in 2x4 and 4x4 variants with manual shifting, electric shifting, or fully automatic transmission. The Rancher 350 was released in olive, yellow, and red body colors.
The Honda Rancher 350 is powered by a 329cc single-cylinder, air-cooled, four-stroke, overhead-valve engine. It features four-wheel-drive capabilities that can be turned on and off via a switch. Rancher 350 models either include a conventional five-speed manual transmission or a continuously variable transmission. The ATV weighs 535 pounds without fuel and can hold 3.4 gallons of fuel. Fuel is delivered to the engine via a single constant-velocity carburetor.
Honda all-terrain-vehicles generally include the VIN (vehicle identification number) stamp on the front left side of the frame, near the A-arm mounts. It features just one vinyl seat in which a rider straddles like a motorcycle. The ATV includes four tires and features sealed hydraulic drum braking for the front tires and sealed drum braking for the rear tires. The Rancher 350 model includes one front cargo rack, rated for 66 pounds, and a back cargo rack, rated for 133 pounds. An optional sealed, water-tight trunk could be purchased for extra storage.
Technical Specifications
Engine:
- Engine Type: single-cylinder
- Cylinders: 1
- Engine Stroke: 4-stroke
- Valve Configuration: OHV (overhead valve)
- Displacement (CC/CI): 329/20.1
- Carburation Type: Carburetor
Transmission:
- Transmission Type: Manual/Automatic clutch
- Number of Speeds: 5
- Primary Drive (Front Wheel): Shaft
- Reverse: Yes
Wheels and Tires:
- Front Tire: Bridgestone® 24 X 8-12
- Rear Tire: Bridgestone® 24 X 9-11
Brakes:
- Front Brake Type: Sealed hydraulic drum
- Rear Brake Type: Sealed drum
Technical Specifications:
- Wheelbase (in./mm.): 49.1 / 1247.1
- Dry Weight (lbs/kg): 535 / 242.7
- Fuel Capacity (gal/l): 3.4 / 12.9
Seats:
- Seat Height (in./mm.): 32.4 / 823
- Number of Seats: 1
Drive Line:
- Driveline Type: 4x4
- Number of Driveline Modes: 1
- Limited Slip Differential: Standard
Storage:
- Rear Rack: Standard
- Front Rack: Standard
Lights: Halogen headlight
Part Numbers:
Front Tire: 24x8x12Rear Tire: 25x9x11Battery: YTX14-BSSpark Plug: DPR7EA-9Oil Filter: 15412-HM5-A10Air Filter: 17254-HN5-670
Additional Information
