crwdns2934263:02crwdne2934263:0
Background and Identification
The 2000 Honda Shadow ACE Tourer is a motorcycle made by Honda. The motorcycle features a V-twin engine, a large windshield, and two color-matched weatherproof saddlebags. Honda Motor Company, Ltd. is a Japanese public multinational corporation primarily known as a manufacturer of automobiles and motorcycles. After World War II, bicycles with auxiliary engines increased in popularity in Japan. Honda’s first mass production of motorcycles began in 1949. Honda began exporting motorcycles to Taiwan and the Philippines in 1952. Since 1955, Honda has been the largest motorcycle manufacturer in Japan.
The 2000 Honda Shadow ACE Tourer’s engine includes an offset-dual-pin crankshaft designed for added power and smooth performance. The motorcycle also features a rubber cushion engine-mounting system. The bike is designed with a free-flowing two-into-two exhaust system with right- and left-side mufflers and long muffler extenders. The motorcycle’s handlebar-mounted windscreen is designed for weather protection. The 2000 Honda Shadow ACE Tourer includes aluminum 11-spoke wheels and wide, low-profile radial tires.
Honda motorcycles can be identified by the Honda motorcycle emblem, which has consisted of a bird’s wing and the name “Honda” in capital letters since the 1960s. The 2000 Honda Shadow ACE Tourer includes one main seat and an additional backrest behind the main seat. It also features a deep front fender for better protection when riding in wet conditions.
Technical Specifications
ENGINE SPECS:
  • TYPE: liquid-cooled, 45-degree V-twin, single pin crank, 4-stroke
  • DISPLACEMENT: 1099 cm^3
  • BORE X STROKE: 3.4x3.6 in OR 86 mm
  • COMPRESSION RATIO: 8.0:1
  • HORSEPOWER: KW(hp)/RPM
  • TORQUE: 0/- lb-ft/RPM OR 0 Nm/RPM
  • FUEL SYSTEM: Twin 36mm, diaphragm-type, CV carburetors
TRANSMISSION SPECS
  • GEARBOX: 5 Speed, manual, wide-ratio
  • CLUTCH: Wet multi-disc, manual
  • FINAL DRIVE: Shaft
CHASSIS SPECS
  • FRAME: Steel
  • FRONT SUSPENSION: 41mm fork; 150mm travel
  • REAR SUSPENSION: Dual shocks with 5-way spring preload adjustment 95mm travel
  • FRONT BRAKE: Single 316mm disc with twin-piston caliper
  • REAR BRAKE: Single 276mm disc with single-piston caliper
DIMENSION SPECS
  • SEAT HEIGHT: 28.7 in OR 729 mm
  • WHEELBASE: 65.2 in OR 1656 mm
  • WEIGHT: 628 lbs OR 285 kg
  • FUEL CAPACITY: 4.4 gallons OR 16.7 L
TIRES SPECS
  • FRONT: 130/80R-18 radial
  • REAR: 170/70R-16 radial
Additional Information
Walter Galan
711.436 crwdns2915208:0crwdne2915208:0
crwdns2935297:01.203crwdne2935297:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 73
crwdns2936753:030crwdne2936753:0 332
crwdns2959996:0crwdne2959996:0 16,842
