'Waste Toner box full' error message
Brother Waster Toner box model WT-223CL. Printer is DCP-L3551CDW color laser. Problem: Readout says Waste Toner box is full, or near full, when it's actually empty.There's a lot of conflicting information on YouTube about this problem but I've yet to find the correct fix. Anyone?
@egelbart sounds like you may have issue with the Waste toner sensor. It detects a certain amount of waste toner in the waste toner box. So, if your repeat message says it s full but in reality it is not, then this would be my prime suspect. Make sure that you reset the "sensor" which is really nothing but a simple switch. Check something like this video for seeing how to do that. Also check and clean the contacts etc. as seen on page 114 of the SM
Use the Brother Dcp 9030cdn L3510cdw L3517cdw L3550cdw L3551cdw Hl L3290cdw Mfc 9150cdn 9350cdw L3710cw L373 for the rest of the SM for the printer.
crwdns2944067:07crwdne2944067:0:
Thanks for the tip.
Is that a manual your link is pointing to?
I can't seem to make it work.
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
@egelbart yes, that is the service manual for those printers. It does not download when you click on it? I did UL to this page Brother Printer under the Documents header
OK, I have the pdf but when I click to open it, all I see is a menu that appears to have been inserted by IFIXIT. Nothing on the menu opens the file.
AI tells me that what I've downloaded (83k) is just the menu, not the 28MB manual.
@egelbart all you should have to do is to click on the blue link in my answer. Once it open in the internal viewer you can click on the three dots on the right beside the magnifying glass and choose download. Just checked it and it does work for me.
crwdns2934275:02crwdne2934275:0
Thanks for the information. Unfortunately, my New Zealand version of the DCP-L3551CDW color laser doesn't have the controls you described, see photo. I assume that somewhere in the machine will be a way of resetting the page counter back to zero, but I haven't been able to find it.
Egelbart crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 75
crwdns2959996:0crwdne2959996:0 75
