lg 75qned80uqa Unfamiliar lines on screen
There are lines on my screen that I am unfamiliar with. Not the typical lines seen in most led tv issues. I am not sure it it is a backlight problem or something else.
@danshea14656 there is a possibility that this originates from the LED on the backlight strip. Your TV uses an Edge LED so if it has rotated or its slightly loose it can cause those artifacts. There is also a chance that this is caused by the diffuser. You will have to disassemble your panel to see exactly what is going on with that.
This is a big panel so you will need to make sure that you have enough help to remove the LCD panel to expose the backlight. Biggest issue will be that you don't flex the LCD panel. Even so it is a large panel, it is flimsy and will try to flex a lot.
Dan Shea crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 34
crwdns2936753:07crwdne2936753:0 34
crwdns2942667:0crwdne2942667:0 34
