Does a "shimm" help with the Airport card socket issue?
Hello!
I've come across a large quantity of G4 12" 1.33GHZ machines. Usually about 1 in 30 has the Airport card socket issue (which causes kernel panics and makes the machine unusable when wireless is on) but in this case it seems 1 in 6 or 7 are having the issue. I usually scrap these machines for parts, but since I'm encountering a lot of them, I'm recalling from years ago that someone mentioned a "shimm" fix that can help the issue.
I'm basically wondering if the "shimm fix" is a viable long-term solution, and if so, how is it done?
Thanks,
John
From my experience there's little you can do to repair the issue but you can try to install a round shim (little rim lock) under the card on the upper left screw hole. That will jack a little the upper card side and make a better contact of the connector to the socket. It worked on 50% of the 1.33 12" models I worked on. I don't remember if it was a 1/8" or 1/4" shim so you'll have to try different scenarios. Also, make sure the the lower gray plastic retainer is tightly secure. Let me know if this solution works for you.
rdklinc crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 526
