Is the ssd upgradable
is the ssd upgradable
Hi @kennethjon74627
You should be able to upgrade the SSD to at least 2TB.
Here's the hardware maintenance manual for the laptop.
Go to p.32 (38 of 56 pdf) in the manual, to view the procedure to remove the M.2 SSD.
The laptop supports PCIe 4x4 (PCIe 4th Gen) and the SSD's physical size is 2242 i.e. 22mm x 42mm so search online for an M.2 2242 PCIe Gen4 2TB SSD to find suppliers that suit you best.
It may support a 4TB SSD but I'm not sure.
If you can't reuse the existing thermal pad or mylar and you need to replace either, the thermal pad part number is 5P20S37692 (examples) and the mylar is 5T10S33783 (examples)
Kenneth Jones crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 84
