لماذا لا يتصل الجهاز بالشبكة الواي فاي
لايتصل الجهاز بشبكة الواي فاي
The most common cause is a settings or system issue, such as enabling the "Auto Restart" feature, or a glitch in apps or the system itself. Sometimes, the cause is hardware-related, such as the battery or motherboard.
  1. 🔎 Possible Causes of Continuous Restarts
- Auto Restart Enabled: Samsung devices have an "Auto Restart" option within Device Care. If enabled, the phone may restart periodically without notification.
- Corrupted Apps or Software: An incompatible or faulty app may cause frequent restarts.
- Incomplete or Corrupted System Update: If a system update is incomplete or an error occurs during installation, it may result in continuous restarts.
- Battery or Hardware Issues: A damaged battery or motherboard/memory problems may cause restarts until the battery is depleted.
- Overheating: High phone temperatures may force the system to restart to protect the components.
  1. 🛠️ Practical Steps for Diagnosis and Resolution
- Disable Auto-Restart:
- Go to Settings > Device Care > Auto-Optimization > Auto-Restart, then disable the option.
- Boot in Safe Mode: This helps you determine if the problem is caused by a third-party app. If the restart stops in Safe Mode, the issue is likely with one of your installed apps.
- Update System and Apps: Ensure your phone is running the latest official version.
- Clear Cache Partition: This may resolve temporary system issues.
- Check Battery and Temperature: If you notice your phone overheating or the battery draining quickly, you may need to check or replace the battery.
- Factory Reset: As a last resort if the previous steps fail, but be sure to back up your data first.
- Consult a Service Center: If the problem persists after all these steps, the issue is likely hardware-related and requires professional inspection.
📌 Summary: Constant restarting is often caused by a settings or software glitch, but if it persists even after a factory reset or in Safe Mode, the problem may be with the battery or motherboard. I recommend starting with the simple steps (disabling automatic restarts, entering Safe Mode, updating the system), and if the problem persists, then visit an authorized service center.
Azhar crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 9
