The Xiaomi Redmi Note 10S is a mid-range smartphone by Xiaomi released March 2021. It has a 6.43" AMOLED display, a 64 MP main camera, a side-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Mediatek Helio G95.
Can't connect to the camera, show
Mere phone Mai jab camera app open Karta hu tab can't connect to the camera and 3 sec mai close app ho jata hai or flashlight bhi option disable ho gaya hai software update bhi nahi kiya achanak se aisa hua hai
Translation Indonesian - English
When I open the camera app on my phone, it can't connect to the camera and closes after 3 seconds. The flashlight option has also been disabled. I haven't done a software update. This happened suddenly.
@jashpalgami there is always the possibility that his is a bad camera. It is also possible that this is a software issue. Start your phone in safe mode and see if you camera works in that mode. If so you know that you have a 3rd party App that interferes with your camera. You would have to uninstall those Apps.
To put your phone in safe mode, press and hold the power button, then press and hold "Power off" on the screen until the "Reboot to Safe Mode" option appears. To exit safe mode, simply restart the phone normally
Since this is an issue with not just the camera but the Flashlight option as well, it is possible that this is a firmware issue. You do want to try a factory reset. Remember that a factory reset will delete all of your files. Make sure that you back those files up first. Yo u will also need to have the email and password that was used when the phone was originally setup. If you do not have that, you will have trouble accessing you phone later.
Since you can still have access your phone, I would do a factory reset from the Settings Menu
  • Open the Settings app.
  • Go to About phone.
  • Select Factory reset or tap on the search icon and type "factory reset" to find the option.
  • Tap Erase all data (or "Factory reset") and follow the on-screen prompts, which will include entering your password or PIN to confirm.
If none of this works and your camera/flashlight consider replacing the flashlight sensor flex cable and check the main board for other issues as well. There is a possibility that this could also be related to the ROM software and reflashing it may resolve this. Since iFixit does not really deal with firmware, software and flashing ROM, check the forums that do. Something like this should work for that,
The reason why this is a bit more complex is simply because of the flashlight option being disabled and the camera not working. You have to rule out software and hardware, but in this case hardware seems to be the less likely cause.
Translation
@jashpalgami Ada kemungkinan kamera Anda bermasalah. Ada juga kemungkinan ini adalah masalah perangkat lunak. Nyalakan ponsel Anda dalam mode aman dan lihat apakah kamera berfungsi dalam mode tersebut. Jika ya, berarti ada aplikasi pihak ketiga yang mengganggu kamera Anda. Anda harus menghapus aplikasi-aplikasi tersebut.
Untuk memasukkan ponsel ke mode aman, tekan dan tahan tombol daya, lalu tekan dan tahan “Matikan” di layar hingga opsi “Reboot ke Mode Aman” muncul. Untuk keluar dari mode aman, cukup restart ponsel secara normal
Karena ini adalah masalah yang tidak hanya terkait dengan kamera tetapi juga opsi senter, kemungkinan ini adalah masalah firmware. Anda disarankan untuk mencoba reset pabrik. Ingatlah bahwa reset pabrik akan menghapus semua file Anda. Pastikan Anda membackup file-file tersebut terlebih dahulu. Anda juga perlu memiliki email dan kata sandi yang digunakan saat ponsel pertama kali disetel. Jika Anda tidak memiliki itu, Anda akan kesulitan mengakses ponsel Anda nanti.
Karena Anda masih dapat mengakses ponsel Anda, saya sarankan melakukan reset pabrik dari menu Pengaturan
  • Buka aplikasi Pengaturan.
  • Pilih Tentang Ponsel.
  • Pilih Reset Pabrik atau ketuk ikon pencarian dan ketik “reset pabrik” untuk menemukan opsi tersebut.
  • Ketuk Hapus Semua Data (atau “Reset Pabrik”) dan ikuti petunjuk di layar, yang termasuk memasukkan kata sandi atau PIN untuk konfirmasi.
Jika semua ini tidak berhasil dan kamera/senter Anda bermasalah, pertimbangkan untuk mengganti kabel fleksibel sensor senter dan periksa papan utama untuk masalah lain. Ada kemungkinan ini juga terkait dengan perangkat lunak ROM dan menginstal ulang ROM mungkin dapat menyelesaikan masalah ini. Karena iFixit tidak menangani firmware, perangkat lunak, dan flashing ROM, periksa forum yang melakukannya. Sesuatu seperti ini seharusnya berfungsi untuk itu,
Alasan mengapa ini sedikit lebih rumit adalah karena opsi lampu senter dinonaktifkan dan kamera tidak berfungsi. Anda harus mengesampingkan kemungkinan masalah perangkat lunak dan perangkat keras, tetapi dalam kasus ini, perangkat keras tampaknya bukan penyebab yang paling mungkin.
Jashpal Gami crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 25
