The Motorola Moto G Power 2022 released February 22, 2022. The device has a 6.5 inch display and a 5000 mAh battery.
Porque no carga el dispositivo Why isn't the device charging?
No carga el dispositivo
Lo conecte y no carga
Translation Spanish - English
The device isn't charging.
I plug it in, but it won't charge.
@carlosmoren7787 first you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you don't get that voltage, check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty; consider replacing that if everything else checks out.
Since iFixit does not yet have any specific guides for this, use something like [Motorola Moto G Power 2022 |this video] Replacement batteries are available here Moto G Play (2023) and Moto G Power (2022) Battery - Genuine and charging boards are currently out of stock on iFixit. Do an online search for that and purchase form a seller that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@carlosmoren7787 Primero, revisa tu fuente de alimentación. Asegúrate de que tenga el voltaje correcto. Comprueba que los conectores no estén doblados, etc. Después, revisa el puerto de carga. Límpialo de residuos, etc., y usa unas cuantas bocanadas de aire para limpiarlo. Asegúrate de que no haya corrosión, residuos, etc. que impidan su funcionamiento. Si nada de esto funciona, consigue un amperímetro y comprueba si tu teléfono consume amperaje del cargador.
También podrías considerar reemplazar la batería. Una batería agotada ya no se puede cargar. Mide el voltaje en el conector de la batería con el cargador enchufado. Deberías obtener alrededor de 4.2 V. Si no obtienes ese voltaje, revisa el cable flexible que sale de la placa de carga. Asegúrate de que esté bien colocado y no tenga roturas ni otros daños. Tu teléfono tiene una placa de carga independiente que podría estar defectuosa; considera reemplazarla si todo lo demás funciona correctamente.
Como iFixit aún no tiene guías específicas para esto, usa algo como este video. Puedes encontrar baterías de repuesto aquí: Moto G Play (2023) and Moto G Power (2022) Battery - Genuine, y las placas de carga están agotadas en iFixit. Busca información en línea y cómprala a un vendedor que te interese.
Mientras trabajas con tu teléfono, toma muchas fotos. Una vez que termines, hazlas y crea una guía para iFixit. Esto ayudará a la próxima persona que tenga un dispositivo con los mismos problemas que tú. Crear estas guías es fácil y divertido. https://ifixit.com/Guide/new La comunidad de iFixit te lo agradecerá.
¡Reparar es la guerra contra la entropía!
crwdns2886500:0Replace a JK50 model battery compatible with a Motorola Moto G Play (2023) or Moto G Power (2022) smartphone. 4850mAh. 18.5 Watt Hours (Wh). 3.8 Volts (V).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$32.99
Carlos Moreno crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 25
