My mouse doesn't turn on or charge.
My mouse doesn't turn on or charge. Everything seems fine, I don't see any faults. What solutions could there be?
crwdns2889612:0crwdne2889612:0
0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 30
It could be the charger. Try using a different one. If that doesn't work, take it apart and check the connections.
crwdns2934271:0crwdnd2934271:0 Fixer of Stuff crwdne2934271:0
I have already had it open, I have done tests and the original works. I tried another one and it still doesn't work. I tested the battery with an object and it showed that it was good, but it still won't turn on. How strange.
crwdns2934271:0crwdnd2934271:0 Jocaxqui Corizez crwdne2934271:0
Uhm.. what does "tested the battery with an object" mean? The image it brings to mind is shorting the terminals with to produce a spark... which is both dangerous and not indicative of a good battery, check it with a meter instead and if there's a part number on it, look it up on the web and see if you can find it, assuming it checks bad. I'm using a fantech venom with a battery that I replaced in this way... I think it's the first time I've had a mouse live long enough (not worn out physically) to actually need a new battery. (FWIW I've not had a Logitech mouse survive long at all... except the ancient trackball.) While you're using the meter check that the switches actually 'switch' (continuity open and closed) especially the on-off one, obviously... they are usually the first things to fail. (can be fixed but a pain)... Good Luck.
crwdns2934271:0crwdnd2934271:0 Juan Garcia crwdne2934271:0
