Xiaomi Redmi Note 5 is a budget Android smartphone, from 2018 that shipped with Android 8.
Tidak bisa di cas Can't be charged
Gimana biar bisa di cas
Translation Indonesian - English
How can I charge it?
@ytta I would start with a new battery. That will give you a known-well starting point for further troubleshooting.
Next check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Since iFixit does not yet have a specific guide for this, use the one from here It is written in French but Chrome and other browsers do a pretty good job of translating it. Replacement batteries are readily available online.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@ytta Saya sarankan untuk memulai dengan baterai baru. Ini akan memberikan titik awal yang jelas untuk troubleshooting lebih lanjut.
Selanjutnya, periksa charger Anda. Pastikan outputnya normal. Kemudian periksa kabel charger. Pastikan konektornya tidak bengkok, dll. Setelah itu, periksa port pengisian daya. Bersihkan kotoran, dll., dengan beberapa hembusan udara untuk membersihkannya. Jika tidak ada yang berhasil, gunakan amperemeter USB dan lihat apakah ponsel Anda menarik arus dari charger. Jika tidak, masalahnya kemungkinan ada pada port pengisian daya atau baterai yang rusak.
Untuk memeriksa port pengisian daya, gunakan voltmeter dan ukur tegangan di konektor baterai. Selanjutnya, colokkan charger ponsel Anda. Sekarang ukur tegangan di konektor baterai. Tegangan seharusnya meningkat. Jika tidak, masalahnya mungkin ada pada port pengisian daya atau sirkuit.
Karena iFixit belum memiliki panduan khusus untuk ini, gunakan panduan dari sini. Panduan tersebut ditulis dalam bahasa Prancis, tetapi Chrome dan browser lain dapat menerjemahkannya dengan baik. Baterai pengganti tersedia secara online.
Saat Anda memperbaiki ponsel Anda, ambil banyak foto. Setelah selesai, gunakan foto-foto tersebut untuk membuat panduan untuk iFixit. Hal ini akan membantu orang lain yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargainya.
Perbaikan adalah Perang Melawan Entropi!
Ytta crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 33
