The Xiaomi Poco M2 Pro is a mid-range smartphone by Xiaomi released July 2020. It has a 6.67" IPS LCD display, a 48 MP main camera, a 5000 mAh battery, a side-mounted Fingerprint, and runs on a Snapdragon 720G.
My Phone charging isn't working
Everytime I plug in the charger it just doesn't charge and now it is off
@mohammadaz94928 you are not giving us enough information. You need to let us know if anything happened to your phone; if it just stopped charging. Also, we need to know what you already have checked and what you have tried to fix it.
First you want to check your phone charger. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get an ammeter and see if your phone draws any amperage from the charger.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. Measure the voltage on your battery connector with the charger plugged in. You should get around 4.2V If you do not get this voltage If you don't get that voltage, check your flex cable coming from the charging board. Make sure it is seated properly and does not have any tears or other damage on it. Your phone has a separate charging board that could be faulty. Consider replacing that as well.
To recap, if your charger is good and you cable is good as well as the port is cleaned of any obstruction, change the battery, then the charging board and check/replace the flex cable form charging board to main board, Since iFixit does not yet have any specific guides for this phone, use something like this video to work on it. Replacement parts are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Not fast charging not otg werking
Update (09/30/25)
And not fast charging
Mohammad Azeem Ashraf crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 70
