My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
crwdns2944067:04crwdne2944067:0
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
@anwar29099
What is the full model number of the laptop that doesn't charge?
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Anwar crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 135
