The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
Why won't my 700r4 downshift?
t.v. cable adjusted properly, spool valve works, and governer is fine but when applying throttle car will not downshift. converter will unlock but no downshift. when slowing to a stop trans downshifts though slightly delayed. trans wasn't overheated and has less than 8000 miles.
I think it might be a stuck downshift valve.
Check out this long discussion about it and see if you can find anything that helps you.
Good Luck
Could be the shift solenoid or the speed sensors chech them is also possible the sence it sat for so long that the filter is just pluged up
No it's &&^&@@ we started working on mine today and found all kinds of $@$* in the pan pieces of clutch etc mine was doing the same thing utube it and Googled it said could be Governor shift sonolid tv cable etc no it has all kinds of metal in pan
Matt, Please let me know what you find out, I have the same trouble, It worked great for a day or so them stopped all down shifting from giving it gas. It will down shift when coming to a stop and no matter the length you set the (TV) it will still not down shift.
It was a sticky valve. This happened after winter storage. Upon further inspection, the cable was being pulled out of adjustment because the valve was stuck. Dismantled for cleaning fixed this problem.
Matt, thanks for the info, I checked for that same issue but the valve was not stuck,removed the 1-2 sevo and rebuilt it and it looked good before I rebuilt it, governor also looks good,now I’m on to the 3-4 sevo, I’ll let you know what’s up after I put it back together.????
matt crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 18,531
