Après être tombé dans l'eau ça ne redémarre plus
crwdns2934073:0crwdne2934073:0
@junior40664 For now, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. Since iFixit does not yet have a specific guide for this, use something like the guides from here. All of them are written in Spanish, use a browser that will do the translations for you if needed.
Remove the main board and the charging board. I have gotten into the practice of replacing the charging board since that gives a known-well starting for any further troubleshooting. Those boards are not expensive and are readily available at many online stores.
You will have to remove all the EMI shields off those boards. If you do not remove the shields, you are not cleaning the board properly. Take a close look at all components and connectors to assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well.
I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. While you clean your boards, check for any obvious damage, like burned or missing components etc. The importance here is the cleaning. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@junior40664 Pour l'instant, arrête d'essayer de recharger, synchroniser ou utiliser ton téléphone. Ça pourrait aggraver la situation et endommager encore plus ton téléphone.
La prochaine étape, c'est de le nettoyer. Comme iFixit n'a pas encore de guide spécifique pour ça, utilise plutôt les guides disponibles ici : les guides. Ils sont tous en espagnol, mais tu peux utiliser un navigateur qui te traduira si nécessaire.
Retire la carte mère et la carte de charge. J'ai pris l'habitude de remplacer la carte de charge, car ça permet de repartir sur des bases saines pour tout dépannage ultérieur. Ces cartes ne sont pas chères et sont facilement disponibles dans de nombreuses boutiques en ligne.
Tu devras retirer tous les blindages EMI de ces cartes. Si tu ne les retires pas, tu ne nettoieras pas correctement la carte. Examine attentivement tous les composants et connecteurs pour évaluer les dommages. Recherche toute corrosion importante, évalue les broches des connecteurs, etc. Examine tous les connecteurs ainsi que les extrémités des câbles. Une fois que tu as nettoyé toute contamination importante, utilise de l'alcool isopropylique à 90 %+ et nettoie à nouveau tes pièces. Pour un nettoyage correct, utilise ce guide. Il a été rédigé pour un iPhone 3G d'Apple, mais toutes les étapes sont également pertinentes pour ton téléphone.
Je ne saurais trop insister sur l'importance d'un bon nettoyage, alors recommencez plusieurs fois en remplaçant l'alcool après chaque nettoyage. Pendant que vous nettoyez vos cartes, vérifiez qu'elles ne présentent pas de dommages évidents, tels que des composants brûlés ou manquants, etc. L'important ici est le nettoyage. Toutes ces étapes visent à éviter une panne tardive causée par la corrosion. L'idéal serait de nettoyer les composants à l'aide d'un nettoyeur à ultrasons, mais si vous n'en avez pas, cette méthode vous aidera au moins.
Après ça, remonte ton téléphone et réévalue la situation. Tant que tu n'as pas nettoyé la carte et remplacé la batterie, tout n'est que supposition. N'oublie pas que les dégâts causés par l'eau sont les plus difficiles à diagnostiquer et à réparer. Peu importe que ton téléphone ait été exposé à l'eau pendant 2 secondes ou 2 heures, ce qui compte, c'est l'endroit où l'eau (les particules) a causé des dégâts.
crwdns2942667:0crwdne2942667:0 31
