Repair and troubleshooting information for the Samsung Galaxy Buds3, the successor of the Galaxy Buds2 in the Galaxy Wireless earbuds series. Released in July 2024.
Why my right bud isn't charging?
the right bud doesn't really charge,what can I do?
i found out it charges if i press it harder in the case. (Don't do this) i added a bit of moisture to the bottom part of the bud so it will make "better contact" ,and for a while it worked, but the case started flashing red, indicating moisture.Now it doesn't charge at all and a pin from the case is white instead of yellow. are my buds done for?
Please check charging contact inside the case may be broken or you can do factory reset. It's the last option if that don't work its time to buy new pair.
NO! aun tienen vida útil! Pero te recomendaría abrir la caja de carga, y limpiar, espero hayas usado alcohol isopropilico, alguna otra cosa si puede afectar
De igual forma, solo usa un cotonete para limpiar la zona interna de los audífonos al igual que el propio audifono
D2n13l1 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 180
