Comprehensive guides and support for a wide range of wearables including the Apple Watch, Android Wear powered watches, Fitbits, and more.
Can't turn on when the charger is removed
mengapa jam tamngan saya tidak bisa menyala setelah casan nya di cabut, tetapi saat di cas hidup
English translation:
Why can't my watch turn on after the charger is unplugged, but when it is charged it turns on?
Hi Sabrina,
Without knowing what make and model watch you have it's hard to be specific about an answer, but in general if a device that runs off a battery only works when the charger is plugged, that usually indicates that the battery has failed and can no longer hold a charge. The usual fix is to replace the battery, but we can't tell you how to do that unless you tell us what your watch is.
Tanpa mengetahui merek dan model jam tangan yang Anda miliki, sulit untuk memberikan jawaban yang spesifik, tetapi secara umum jika perangkat yang menggunakan baterai hanya berfungsi saat pengisi daya dicolokkan, itu biasanya menunjukkan bahwa baterainya rusak dan tidak dapat lagi menyimpan daya. Perbaikan yang biasa dilakukan adalah mengganti baterai, tetapi kami tidak dapat memberi tahu Anda cara melakukannya kecuali Anda memberi tahu kami jenis jam tangan Anda.
Sabrina Farhanisah crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 10
