Won't charge after new battery install
Just installed new battery with your kit and the charger port is not working.
Did you disconnect the battery first before everything else,
If it was charging before remove all the cables again then reseat them all making sure they seat securely then try it. Try leaving it plugged in for half hour to an hour to see if it kicks in.
Yes, I followed all directions and order of operations. Prior to install, everything was working. The original battery was just starting to swell, so I ordered this replacement. Phone works as it should and new battery had approx. 73%. I will to leave it plugged in and see if it start charging at some point.
I left it plugged in for over an hour and nothing. Any ideas?
I got it to charge finally. Let the battery run down per instructions and now I can't get it to charge consistently. I been through the instructions back and forth, and it will only start charging inconsistently. I've already ruined the adhesive and a back. Before I reinstall the new back, I want to make sure it works like it did before the new battery.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 27
