Power Button doesn't work
The button doesn't respond at all
@siphumelel69527 have you checked for power on your laptop? Any LCD's lighting up or blinking when you connect your power adapter?
Well try the following it some the basic way to fix this issue:
  • Check charger & power outlet: Ensure the laptop is plugged in and the outlet works.
  • Battery indicator: If any lights turn on when plugged in, the laptop may still be functional.
  • Unplug the charger and Remove the battery (if removable) And then Press and hold the power button for 30 seconds.
  • Reconnect the battery and charger, and try turning it on.
Siphumelele NDLOVU crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 8
