The Samsung Galaxy A22 5G is a mid-range Android-based smartphone developed and manufactured by Samsung Electronics as a part of Galaxy A series. The phone was first released on 24 June 2021. The phone comes with a triple rear camera setup and a 90 Hz display. The battery has 5000 mAh, which is 62% bigger than the battery of the iPhone 13 Pro.
My phone's network disappears
"My phone's network disappears, and as soon as the network disappears, the phone automatically turns on and off, and it doesn't work. Then, when I turn it off, after a while, I turn it on again, and it works for a short while, then the same problem occurs."
Well You can try the following fix it might help you in fixing the issue on your phone:
  • Toggle Airplane Mode
  • Restart Your Phone
  • Reinsert SIM Card
  • Try a Different Location
  • Check Network Mode
  • Reset Network Settings
  • Check for Software Updates
  • Try Another SIM Card:
  • Factory Reset your phone (before factory reset backup your data)
Primary crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 156
