Washer sounds like it's being murdered
I don't think I have the right model number in my device choice, but it's an LG to load washer.
When there's about 15 minutes or so left in the rinse cycle My washing machine makes this horrible noise. I've tried to attach a video I took. What could this be?
crwdns2944067:06crwdne2944067:0
Hi @mpisani96626
What light is seen blinking in the washer's display screen?
Is water still entering the washer to rinse the clothes or has it filled sufficiently and stopped filling before the noise starts?
Does the machine spin OK in the spin cycle
I'd have to check to see what light that is. Water comes in and out no problem and it spins fine.
Yes. I only notice it at the end of the wash when there's about 11 minutes or less left. I don't know if it's trying to balance the wet close or what. I'm hesitant to call a repair person if it's something I could do myself but I wouldn't know where to start.
@mpisani96626
Has all the water been drained out of the washer when this happens?
Not sure if it is a drain pump problem or a drive motor problem.
I'll have to check next time to see if the water is drained out. I think it is and it's getting ready to spin.
It sounds like it might be a load imbalance causing the issue.
Try running with no clothes.
Since it only occurs at a specific time, you can just run it thru the rinse cycle.
With that glass top, you should be able to see if the tub is warbling.
Thanks. I'll have to try just rinse without clothes. I think its trying to balance, but when we first got it, I never remember hearing the noise it makes. I'm just wandering is there's bearings that need to be replaced, or what it could be.
mpisani crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 134
