Available - March, 2013. Display - 1080 x 1920 pixels, 5.0 inches, 16M. Internal Memory - 32 GB, 2 GB RAM. Chipset - Huawei K3V2. CPU - Quad-core 1.5 GHz, Cortex-A9. Primary Camera - 13MP. Android OS, v4.1 (Jelly Bean).
لماذا لا يعمل هاتفي Why isn't my phone working?
ميت كيف اعرف العطل
Translation Arabic - English
It's dead. How do I know what's wrong?
@ehsano you are not giving us enough information. You should consider to letting us know if anything happened to your phone, if it just all of sudden stopped working or if anything happened to it. Also, Let us know what you have checked and what you have already tried to fix it.
For now you want to start by first checking your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an USB ammeter and see if your phone draws any amperage from the charger. If it does not, it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. If not then the issue is either the port or the charging circuit.
To actually work on your phone and to disassemble it etc. Go to this page Huawei Ascend D2 and scroll down to Documents. You will find the Huawei Ascend D2 Maintenance Manual. Use that manual to work on it.
Translation
@ehsano، أنت لا تزودنا بمعلومات كافية. يُرجى إعلامنا إذا حدث أي شيء لهاتفك، أو إذا توقف فجأة عن العمل، أو إذا حدث له أي شيء. كما يُرجى إخبارنا بما تحققت منه وما حاولت إصلاحه.
في الوقت الحالي، ابدأ بفحص الشاحن. تأكد من أن خرجه سليم. ثم تحقق من كابل الشحن. تأكد من عدم ثني الموصلات، إلخ. بعد ذلك، تحقق من منفذ الشحن. نظفه من أي أوساخ، وما إلى ذلك، باستخدام بضع نفخات من الهواء لتنظيفه. إذا لم ينجح أي من هذا، فاحصل على مقياس تيار USB وتحقق مما إذا كان هاتفك يسحب أي أمبير من الشاحن. إذا لم ينجح، فمن المحتمل أن تكون المشكلة في منفذ الشحن أو البطارية تالفة.
لفحص منفذ الشحن، استخدم فولتميتر وقم بقياس الجهد على موصل البطارية. بعد ذلك، وصّل شاحن هاتفك. الآن، قم بقياس الجهد على موصل البطارية. من المرجح أن يكون هذا الجهد قد ارتفع. إذا لم يحدث ذلك، فالمشكلة إما في المنفذ أو في دائرة الشحن.
للعمل على هاتفك وتفكيكه، وما إلى ذلك، تفضل بزيارة هذه الصفحة Huawei Ascend D2 وانتقل إلى قسم "المستندات". ستجد دليل صيانة Huawei Ascend D2. استخدمه للعمل عليه.
Ehsano crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 80
